Geplaatst: Do Sep 22, 2011 4:29 pm Onderwerp: |
Adrianus J.M. Houtsma
In: NAG-journaal, 1998, 143, 31-38
Norms and limits for admissible noise, as specified in the law, are always stated in terms of physically measurable attributes and are often determined and applied with a precision of fractions of a decibel. Human perception and memory for sounds, however, are not so accurate to justify discussions about fractions of a dB. Differential sensitivity for sound intensity is, under ideal conditions, approximately one decibel. Under more realistic conditions differential thresholds are considerably higher. Noise intensity levels for which members of a test population indicate to be severely annoyed show a typical interquartile spread of about 20 dB. Correlation coefficients between reported annoyance and actually measured sound levels, as has been done in many professional survey studies, are typically around 0.3. This implies that only 9% of the variance in the annoyance ratings can be explained by the physical sound level. The great variance in perceptual annoyance data seems to a very large extent due to psychological, non-acoustic factors and only to a much smaller extent due to insufficient control of the acoustic measurements.
Gevonden hier:
http://www.industrialdesign.tue.nl/jfschouten/research/publications/publications1998.htm |
Geplaatst: Do Sep 22, 2011 4:42 pm Onderwerp: |
Een beetje het Robert Herik-verhaal: de overheid gaat ervan uit dat iedereen helemaal gek wordt van verkeersgeluid terwijl er hordes bejaarden zijn die naast de autobaan willen wonen omdat ze dan iets te kijken hebben. |
Geplaatst: Do Sep 22, 2011 5:49 pm Onderwerp: |
Leuk om Prof. Houtsma hier te zien 'opduiken' (ik ken hem persoonlijk). Ik zal hem eens wijzen op dit topic! _________________ - Ook ú kunt (als geregistreerd gebruiker) beschikken over een onderschrift - Klik hier
RAFSmeets
Sinds: 22-9-2011 Berichten: 1 Woonplaats: Herten
Geplaatst: Do Sep 22, 2011 9:43 pm Onderwerp: |
Naaldbomen zijn volgens mij hier het meest geschikt voor, al zal het effect (op zowel geluid als luchtkwaliteit) zoals al eerder aangegeven beperkt zijn. Daarnaast is het beter om ook op lagere hoogte een dichte begroeiing te realiseren.
In Amsterdam gaan ze experimenteren naar bamboe, ik ben benieuwd naar de eerste meetresultaten!
bamboe geluidscherm |
Houtsma Gast
Geplaatst: Vr Sep 23, 2011 9:54 pm Onderwerp: Akoestisch Dilemma |
Allereerst, de nederlandse term "akoestisch dilemma" is bij mijn weten het eerst
gelanceerd door drs. Ben Lopes Cardozo van het IPO/TUe in Eindhoven in de
syllabus die hij indertijd heeft geschreven voor de Hogere Kursus Akoestiek in
Antwerpen.
Voorts behoren aan mijn genoemde artikel in het NAG Journal van 1998, altans
voor de echt geinteresseerden, te worden toegevoegd:
(a) Het klassieke artikel van Ted Schultz in J. Acousti Soc. Am. (JASA) Vol 64,
Pag. 877-405 (1978)
(b) Twee publicaties van Hans Miedema en Hans Vos in JASA 104, 3432-3445
(1998) en JASA 105, 3336-3344 (1999) waarin zij aantonen dat er een systematisch
en significant beoordelingsverschil is tussen de ervaren hinderlijkheid van, resp.,
vliegtuiglawaai, wegverkeer, en treinlawaai.
Aad Houtsma
Cumming, GA, USA |
Geplaatst: Vr Sep 23, 2011 10:37 pm Onderwerp: Re: Akoestisch Dilemma |
Houtsma schreef: | Allereerst, de nederlandse term "akoestisch dilemma" is bij mijn weten het eerst
Antwerpen.
Pag. 877-405 (1978)
Aad Houtsma
Cumming, GA, USA |
Dank voor deze toelichting! Erg leuk! Ik neem aan dat V. ook de hartelijke groeten (ook aan E.) heeft overgebracht? Zo niet dan bij deze. Al het goede aldaar gewenst en hopelijk treffen we elkaar tijdens jullie volgende bezoek aan Nederland? _________________ - Ook ú kunt (als geregistreerd gebruiker) beschikken over een onderschrift - Klik hier
Geplaatst: Zo Sep 25, 2011 12:14 am Onderwerp: |
Al die info is dus helaas zorgvuldig opgeslagen bij van die retecommerciele instituten die elke dollarcent eruit knijpen.
Of is er nog ergens iemand met een anarchistische link? |
Geplaatst: Ma Nov 07, 2011 9:31 pm Onderwerp: |
Ondertussen heb ik firma gecontacteerd voor een grote geluidsberm te maken.
15de komt er ingenieur voor concrete plannen. |
Geplaatst: Do Feb 16, 2012 9:11 pm Onderwerp: |
Vandaag zijn de eerste geluidsmetingen gedaan voor de bouwvergunning.
75Db(A) in de tuin GEMIDDELD..
Niet slecht toch. |
Geplaatst: Do Feb 16, 2012 11:23 pm Onderwerp: |
Anonymous schreef: | Vandaag zijn de eerste geluidsmetingen gedaan voor de bouwvergunning.
Niet slecht toch. |
Dat is flink maar niet vreemd zo dicht op de snelweg... _________________ - Ook ú kunt (als geregistreerd gebruiker) beschikken over een onderschrift - Klik hier
Geplaatst: Za Feb 18, 2012 11:32 pm Onderwerp: |
Ik had eerder rond de 70 gedacht. Aangezien mijn topic vanaf nu niet echt meer relevant is met de topictitel. Mag deze dicht en zal ik een nieuwe openen waarin ik gans mijn project in 1 topic plaats.
Mvg,
Bregt |
bregt14 Gast
Geplaatst: Do Okt 11, 2012 10:48 pm Onderwerp: |
Dat is nogal een project zeg!!!
Kan je op je eerste foto eens aanduiden waar je die dam zou willen leggen?
Alleen langs de baan of ook met een hoek.
Zou je die volledige 220 m willen doen? Dat zijn nogal een bende vrachtwagens aan grond: 11 meter breed en 6 m hoog over een lengte van hoeveel????? |
Geplaatst: Zo Okt 14, 2012 12:34 am Onderwerp: |
hier een 3d-tekening uit mijn bouwvergunning:
bregt14
Sinds: 14-10-2012 Berichten: 24
Geplaatst: Ma Okt 15, 2012 12:05 am Onderwerp: |
Ik heb me even geregistreerd. Zo is het gemakkelijker van jullie op de hoogte te houden. |
